Wd 45 charging system
Mountain goat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Topic: Wd 45 charging system
    Posted: 11 Jul 2025 at 11:58am
Having trouble with charging. all wires look to be in order. It has 12 volt delco Remy genny and voltage regulator 15 volts from regulator wen running 30 0 30 ammeter doesn't move much.is the 3 position light and charging switch and 30 0 30 gauge capable to run a 12 volt system
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 5:26pm
run wire from generator through Amp meter - not through light switch , allow the regulator to monitor charge . Any draw , ignition , lights would be drawn off the - side of amp meter . ( this would be with a key or shut off switch in system ) 3 wire regulator - NOT cutout relay on generator .
Edited by Coke-in-MN - 11 Jul 2025 at 5:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 5:33pm
12v systeems do NOT use the light switch.. Switch contained a RESISTOR to help controm amp output of the 6v generator... A 12v system needs a VOLTAGE REGULATOR.. If the Generator is putting out voltage and you have EXCESS charge, then the REGULATOR is not set right.. Sometimes the easy way out is to get a new regulator as compared to trying to adjust it.
If you need more PARTS to fix the generator system, you might consider a 12v alternator with INTERNAL regulator... Very simple and effective..
12v GENERATOR system with REGULATOR...
Edited by steve(ill) - 11 Jul 2025 at 5:35pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 7:17pm
Originally posted by Mountain goat Mountain goat wrote:
Having trouble with charging. all wires look to be in order. It has 12 volt delco Remy genny and voltage regulator 15 volts from regulator wen running...
Exactly where are you measuring this 15 Volts? If it is at the battery, then yes, it is indeed charging the battery.
... 30 0 30 ammeter doesn't move much...
Please define "doesn't move much". If the battery is getting 15 Volts then it is probably fully charged. in which case the ammeter will not move much; in fact, it should read almighty close to zero when the battery is fully charged.
...is the 3 position light and charging switch and 30 0 30 gauge capable to run a 12 volt system
If you discharge the battery to a very low level then a 12 volt generator may peg a 30 amp gauge for a while until the battery gets charged up again.
As Steve mentioned above, a 3 position light switch has no business being used in this application.
Edited by Les Kerf - 11 Jul 2025 at 7:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 8:34am
The battery wire is going through the meter but the L wire is going through the headlight switch. My 15 volt reading was straight off bat post of the regulator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 8:37am
The gauge moves 1/16 inch wen i turn on lights
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 8:58am
It is set up like diagram except i have L terminal on the reg that goes to headlight switch and ignition switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 9:14am
Ok wat about the L wire coming off the regulator which i think is always live and is powering lights n ignition
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 9:58am
... My 15 volt reading was straight off bat post of the regulator
The generator and regulator are both working correctly. 15 Volts is a bit high but if you are only doing short runs it will cause no harm. If you take it out in 100 degree weather and cultivate crops with it for 12 hours straight it will overcharge the battery so best to turn on the lights.
I prefer to take the reading at the battery because that is what you are actually trying to charge.
...The gauge moves 1/16 inch wen i turn on lights...
Which direction, does it stay on the Charge side or does it go to the discharge. Also, is this a Negative ground system or is it still Positive ground?
Your L wire feeding lights and ignition is fine.
I should have been more clear in my previous post about the 3 position light switch; it is ok to use it to control the lights, but NOT ok to use it in conjunction with a bona fide regulator such as you have. It sounds like you are using it correctly; though, just don't attempt to connect the resistor on the light switch to anything, it is fine to leave it in place (unconnected) or remove it if you wish on your 12 Volt system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 10:04am
I ran test today n only got 12 volts coming out of regulator. Does anyone know how to test the genny
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 10:06am
some regulators have 4 terminals.. the "L" wire is a hot wire connected to the "B" terminal and does not go thru the regulaltor.. It would be the same as connecting the headlights to the amp meter terminal...  no problem..... like Les said, you normally expect to see a little less than 15v... Its possible your voltmeter is old ( or are you using a digital) and you really have 14 or 14.5v .... either way , 15v is not a BIG problem..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 10:08am
Needle moves toward discharge wen i turn on lights otherwise it doesn't move
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 12:40pm
to test a generator... put your volt meter in the A terminal of the generator... best to remove the wire on that terminal that goes to the regulator.... other lead of volt meter to GROUND/ FRAME / neg battery terminal..engine running, take a Jumper wire from the "F" terminal and touch it to the GROUND...
this will BYPASS the GEN and FIELD coils of the regulator and let the generator run wide open...the battery itself acts as a "regulator"... tries to keep the generator down to 15 volts... when you take the regulator wire off the "A" terminal and the battery is no longer connected ( to the generator) .,  the generator might put out 20- 30 volts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 12:53pm
K ill try that thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 2:38pm
0 volts from the genny maybe i can clean it. Wat u think?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 3:10pm
At what speed? It won't charge at all at low idle speeds, rev it up to wide open throttle. When all is correct, this will energize the cutout relay inside the regulator which will then send the charging current to the battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 4:28pm
It was 1/3 throttle . the genny had a stuck brush spring wasn't pushing it tight .gonna put it back on n try it now
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 5:49pm
Rev it up and check the voltage right at the battery post Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 9:08am
Well i put the genny back on and im getting 13 volts to the battery at 3/4 throttle. I guess that's good enough for now she's got alot of hay to bail. Thanks for the help guys saved me alot of time n headaches. I only got about 5 starts out of her before.now im up to 8 and still seems to be fully charged
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 9:19am
you can ground the "F" terminal or remove the "A" wire on the generator, and see what voltage you have at the GENERATOR.... Possibly the genny is putting out way OVER 13 volts and the REGULATOR is what is setting the charge......... 13v is a little low, but should be fine if your using the tractor and getting that TRICKLE CHARGE for  an extended run time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 9:41am
Ok thank you ill do that when the hay is done.i did clean the points on the reg and polarized it
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 9:45am
an alternator needs excitation to make it "START"... a generator just needs to spin.. the faster it spins, the more VOLTS it puts out.... When you connect the BATTERY, then the BAT acts as the SINK or STABALIZER and trys to hold the voltage back to 15 volts.. the VOLTAGE REG refines that to 14.xx output ............. A 12 v generator can put out 30 volts if you remove the battery..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 9:52am
10-4
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 2:03pm
13 Volts in hot weather will keep you running just fine, doing short runs in the winter will need a bit more in order to to keep the battery up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 2:42pm
That'll work just fine
