WD 45 changing rearend |
graveyard
Topic: WD 45 changing rearendPosted: 29 Dec 2015 at 9:51pm |
Some help please I asked this question last year and had a good response. Wanting to put d17 ring and pinion into wd 45. Any ideas or show me how to search old posts of mine thanks!!!!!
Posted: 30 Dec 2015 at 5:50am |
You need the ring and pinion from a WD-45 diesel or an OLD D-17.....newer D-17's were just a little different in main shaft length.
8070
Posted: 30 Dec 2015 at 1:17pm |
What the how many teeth on a DSL rand p of a 45 ..
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Posted: 30 Dec 2015 at 3:08pm |
what state are you in?
Posted: 30 Dec 2015 at 4:17pm |
9 teeth and 35 teeth on the D-17 and WD-45 diesel......15% slower than a regular WD-45 gas.
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 30 Dec 2015 at 6:49pm |
ok will the old d17 ring and pinion fit a plain wd
Posted: 30 Dec 2015 at 7:22pm |
NO.
8070
Posted: 31 Dec 2015 at 10:52am |
U can do it but u got find the rightsize baiting and use all 17 gamers in it and it should work
Posted: 31 Dec 2015 at 11:58am |
The old WD's are a sliding gear style transmission with roller bearings on the countershaft. The ring and pinion from a WD-45 or D-17 will NOT work in that transmission housing. It is simply different and none of the gears interchange. Now, if you wanted to try and machine the housing for Timken bearings on the countershaft, and graft a WD-45 transmission inside it then?? maybe, but why would you go to all that work when you could change the whole rear end as-is??
bigcountry48
Posted: 31 Dec 2015 at 4:01pm |
I agree with doctor Allis, you'd be better off to just unbolt everything from the bell housing back and replace it with either a wd45 or wd45 diesel rearend. I unbolted my frame rails and the six bolts from the bell housing, and it was as simple as sliding the rearend out, switching tires, and sliding the new rearend in.
1950 B, 1952 pulling wd, and 1954 wd45
56allis_msu
Posted: 02 Jan 2016 at 7:51pm |
Find you a diesel rearend and save yourself a whole bunch of time and headache. Me and a friend had mine swapped in no time. Rearends aren't plentiful but I'd check with Tony C and he could probably hunt you up one.
MACK
Posted: 06 Jan 2016 at 8:11am |
The old WD trans. won't take much HP. MACK
orange
Joined: 09 Apr 2011 Location: watertown s d Points: 140 |
Posted: 06 Jan 2016 at 8:21am |
I have a wd-45 rear end assy would sell (diesel) in S.D. Are you in Missouri?
terrykaaz880@tnics.com |
graveyard
Posted: 08 Jan 2016 at 7:18pm |
Ky it is a series 3 but it is free
NDBirdman
Posted: 21 Jul 2016 at 5:02pm |
I'm a little late to this party, but I have a question. What would be the advantage to swapping a WD45 rear-end onto a WD? I ask because I will soon have a 45 without an engine. I have a WD with a decent eng. Besides changing from straight cut to helical cut gearing, is there another reason? |
Posted: 21 Jul 2016 at 8:31pm |
depends on the HP level. the helical gear transmission is stronger. The WD transmission has a low gear of 2.5 MPH and the WD-45 is 2.3 MPH. Doesn't sound like much, but when you use 38 inch tires the difference becomes more pronounced....faster is better if you must use low gear, as long as you have enough engine, that is. Second gear and third gear speeds are identical between the two transmissions.
