WD 45 Brake Springs
WhiskeySup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WhiskeySup Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Brake Springs
    Posted: 24 Jul 2011 at 8:59pm
Got to poking around my WD45 today. Removed the brake covers on both sides and discovered that all four springs (large and small) are broken at the opposite end of where they go around the pins on the shoes. They looked kind of rusty but my question is where do they connect to ? The diagram in the manual does not show where, it just says to use a wire to pull them through. Do they mean the hole in the axel case? What holds the end of the spring?
Thanks,
Jon.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 9:14pm
The axle case is what holds the end of the spring.
When installing new springs, DO NOT nick the spring.  Use a smooth hook or wire to pull the spring.
After attaching the spring,  adjust the brakes.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 8:42pm
  just got a new shippment in $6.75 ea   1-800-254-3116
