WD 45 Air Cleaner Modification?? |
FireMedic
Joined: 07 Oct 2024 Location: Minburn, Iowa Points: 10 |
Topic: WD 45 Air Cleaner Modification??Posted: 11 Nov 2024 at 12:03pm |
Hey guys,
I have a 1956 WD45. I use it for general maintenance and work around the property. I am struggling to find an oil bath air cleaner that isn't rusted out. Mine is absolutely destroyed, and I don't even feel comfortable having it attached to the carburetor at this time. Has anyone ever modified their tractor to use a more modern air-cleaning process, filter or otherwise? I am more concerned with function and maintaining the quality operation of the tractor than keeping it original. Thinking I might modify it to have a straight pipe out the top with a motorcycle-style cone air filter out the top. Or possibly fabricating a mount for a forklift air filter housing. These have a replaceable filter, run about the same size housing, and are only $50. But these are just ideas. Side note, if anyone has any eccentric pins or the entire assembly, I stripped one out while narrowing my wheel base. Nobody online has them for the WD. And eBay isn't really where I want to purchase right now. Too much risk of not getting the entire assembly or the square head version from other models. |
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 553 |
Posted: 11 Nov 2024 at 1:05pm |
My oil bath cleaner wasn't as far gone as yours. It simply was packed with dirt and obviously never seen a pre-cleaner. Until I could get it off & cleaned up, I fastened a K & N cone filter RC-1250 directly to the carb using piece of hose & a couple of clamps. The "correct police" wouldn't care for it, but it worked. The cone is not very big & I was worried if enough air was getting through. Just used on a bush hog so not a continuous heavy load-power was ok. I wouldn't think a bone yard find of a used one would be that difficult. Try contacting Austin Salvage in Butler, Mo.
Posted: 11 Nov 2024 at 4:48pm |
I don't think those K & N filters (that require oil on them to work) were ever intended for farm tractor dust and dirt.
Dennis J OPKs
Posted: 11 Nov 2024 at 5:27pm |
Probably not. This filter is dry/washable & probably for a motorcycle application. It was a short-term fix and not subject to dirty field tillage conditions. Sometimes I improvise when waiting for a permanent proper fix, especially on the old stuff. The pullers use some variation of this but they're not in much dirt or dust either.
Kenny L.
Posted: 12 Nov 2024 at 1:22am |
If you want to take a three hour trip I've both of what you want or you can go to Colfax tractor parts which isn't the far from you, 10447 field ave. Colfax, Ia 515-674-3001
Edited by Kenny L. - 12 Nov 2024 at 1:26am |
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2041 |
Posted: 12 Nov 2024 at 5:00am |
I have a couple nice original air cleaner assembly's for sale. Located in Elk River Minnesota.
http://lonsallischalmers.com
mruhlig77
Joined: 19 Aug 2014 Location: central Indiana Points: 595 |
Posted: 12 Nov 2024 at 8:03am |
I have plugged the bottom of oil bath cleaners and filled them with diesel a time or two...
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4144 |
Posted: 12 Nov 2024 at 8:09am |
I'd talk to Lon. Colfax might have one but I wouldn't bet my bottom dollar on it. Not many 45's sitting around over there last I knew. If all else fails, I might have a good one around here somewhere. Only 7 miles from the Colfax yard so a trip here wouldn't be much further.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12024 |
Posted: 12 Nov 2024 at 8:34am |
Get it from Lon. He'll take care of you. He can probably ship it out to ya. Steve@B&B
Michael V (NM)
Posted: 12 Nov 2024 at 11:57am |
I remember years ago,, maybe long enough to have been on the 'old forum,, someone had replaced the oil bath air cleaner with a dry air cleaner. It was one like the larger ,late models but fit in place of the original oil bath..
ya might search some name brand air cleaner for something similar.. |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3074 |
Posted: 12 Nov 2024 at 1:11pm |
There are soo many WD45's it shouldn't be hard to find one. Orange Knight or Bill Deppe probably have some. Orange Knight's probably scrapping some right now to prepare for his move.
