wc
pete359a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete359a Quote  Post ReplyReply Direct Link To This Post Topic: wc
    Posted: 11 Mar 2011 at 6:56am
need info on a styled wc. what years built, what are the worth.    tin good, looks good, coould have been restorted, but has been sitting and wont run. starter may be out.if i bought it, it needs to e cheap.   starter is like 180 bucks around here.
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 7:54am
Late 38-1948 on the styled.  good tin but non-runner in the $4-500 range-if all there and tires/rims ok.
Thanks
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 1:48pm
i have one also...
this has alot of info on it. GREAT TRACTOR IF YOU CAN GET IT TO RUN!
Great-granfather's WC---- hopefully many more to come!
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete359a Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 8:59pm
thanks for the info.   i think itll be ok, you know how the gas is these days and the young guys are so much in a hurry to crank the hell out of on old 6 volt statrter with a 12 volt battery.   my grandpa had one just like this and used it for years wit a homade loader on it pushin snow. also had cultivator with mech lift.   was a hard steering unit, as the lower bearing was bad for years, even steered hard with no implement mounted on it.
This page was generated in 0.120 seconds.
