wc
mike kennedyididitok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike kennedyididitok Quote  Post ReplyReply Direct Link To This Post Topic: wc
    Posted: 16 Jul 2023 at 6:40am
how does one tell a distillate from gasoline engine? compression test? carb?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2023 at 1:15pm
Not certain about this but I thought all distillate units had a small gasoline tank to start on then switch over when warmed. Should be under hood on rt side I think. Don't think you can start on distillate alone.:
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2023 at 3:28pm
I would think the "starter fuel" tank and the "K" after the engine serial number would be the only way
from the owners manual-
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2023 at 9:55am
I think also a K manifold unless it’s been changed. Isn’t needed unless you plan to use distillate.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
