WC With Oil Pressure SLOW to come up.....
OldAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldAC Quote  Post ReplyReply Direct Link To This Post Topic: WC With Oil Pressure SLOW to come up.....
    Posted: 22 Dec 2023 at 8:20am
I have a WC that the oil pressure is very slow to come up. Its great oil pressure once it does, but its much slower getting there then my other WC's and WF.
It has the fram loose pack filter on it with the proper tube.
It almost seems that the oil all drains out of the filter and dosn't show much pressure till it takes while to fill again.
Thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2023 at 8:27am
To drain backward, you normally have a small leak on the outlet side of the pump..that lets air in and the oil leaks back thru the pump into the crankcase... It could be internal at the pump fitting where you can not see it... .. but could be external..
Look for any damp spots in the filter  / o-ring area... oil tubing fittings ... anything that could be a VERY SMALL damp spot that could mean air leaking BACK when shut down... You might want to remove the filter, clean the o-ring , inspect the seal and reinstall... just a possibility.
Edited by steve(ill) - 22 Dec 2023 at 8:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2023 at 11:10am
If you shut it off and restart it does it come right up to pressure?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2023 at 1:46pm
I'm wonderin' if the oil pickup tube is partially clogged.  Might be worth droppin' the pan and doin' a little invesagation..Sorry, that's Jersey talk for investigation. The ole' girl might need a little clean up in the old oil pan..I dropped the pan one day in my WC. Didn't know it weighed about 45 lbs with all the muck in it. Almost clobbered ma'self in the head!....
Steve@B&B
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2023 at 5:31pm
way overfill it like a gallon over full and see what it does  , if it commes up faster i think you are sucking air some where between the pump and sump  my c had  a hair line crack in the sump tube up real hight and would struggle to get preasure
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2023 at 5:32pm
prove your gauge
