WC/WD puller
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: WC/WD puller
    Posted: 02 Sep 2015 at 2:25pm
A friend of mine is talking about building a WC or WD and putting a D-19, 180 or 190 gasoline engine in it. His question is will these engines bolt in without an adaptor?
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2015 at 2:39pm
An adapter is needed. I have a WC with a 262 6 cyl already installed for sale, send a message if interested.
worldchamp19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2015 at 8:11pm
What kind of adapter did you use to connect a wc and 262?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 9:06pm
Use the adapter and flywheel from a WD45 diesel for the 262. For the 301, you will have to make the adapter and use WD45 diesel flywheel.  If you plan on turning more than 3000 RPMs , use a steel flywheel.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2015 at 4:54pm
Thanks Mack!
