WC, WD , and WD45 Heads ????
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Topic: WC, WD , and WD45 Heads ????
    Posted: 28 Dec 2011 at 11:10am
OK what the differencein the heads, to the running of the tractor?
Cooler, ported different?
Why the taller WD45's heads ?
Gaskets, Valve Size, Guides, and the Push Rods are the same? right?
Thanks !!  Teddy
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 11:53am
The 45 head has more cooling and the 45 head gets the spark plug closer to the center of the combustion chamber.  Other than that, I'm not real sure.
AaronSEIA
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 3:15pm
Teddy, that's a good question.....I been told not much difference, performance wise
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 4:34pm
The Tall head, introduced on the WD in mid 51 and carried over to the WD45, moved the plug toward the center of the combustion chamber and eliminated the little pocket the plugs sat up in before.  It unshrouded the plug for less fouling and increased compression just a little.
