WC Transmission control, repair
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Topic: WC Transmission control, repair
    Posted: 21 Jun 2010 at 4:51pm
Took on the task today of taking apart, cleaning and re-assembleing the shift tower or transmission control as AC calls it for my WC project.  Learned a trick today that may help others here, and that is when putting everything back together and you are installing the detent springs and balls a short peice of brake line with a flared end  will allow you to press down without slipping and launching the balls and springs as you insert the shafts.  Worked for me.   Gary
This page was generated in 0.161 seconds.
