wc starting problems
archiemc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote archiemc Quote  Post ReplyReply Direct Link To This Post Topic: wc starting problems
    Posted: 11 May 2016 at 7:50pm
my wc wont start, it will backfire thru the exaust and also sputter thru the carburter
it last run last fall,but it needed almost full choke. I have cleaned the carb with gunk
replaced the needle and seat and gaskets,had the mag off and clean points
it has run twice for about 10 seconds then dies. if hit starter 3-4 revs gas will pour out the carb
please help
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2016 at 9:13pm
Sputtering through the carb is an indication of a stuck valve to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote archiemc Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 5:34am
Did compression test, #1=125 psi 23&4 150 ps so believe valves oki
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 5:58am
Did you get the mag put back on exactly like it was? Could be a little out of time.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 6:17am
One of two things. Either you still have a stuck valve, or the Mag timing is off a tick.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 6:52am
mag timing, carb is trying to flood (check AND clean your plugs), Fuel....
If you are using an ethanol based fuel, get rid of it. I only use Non-Ethanol in my tractors as the ethanol is Hydroscopic (google it) and will add moisture to your tank which turns into water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 8:22am
Funny my WC sat all winter with E10 in it and fired off on the 4th pull of the hand crank. Did the same thing the last several winters. Check the sediment bowl. If no water there, that's not the problem.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote archiemc Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 4:37pm
Problem solved
the plug wires go into the mag clockwise don't know why i put them in counter clockwise
no wonder it it would blow out both ends
thanks every one for your thoughts and ideas
This page was generated in 0.324 seconds.
