WC Starter and Distributor Points |
jshoemaker
Topic: WC Starter and Distributor PointsPosted: 03 Oct 2010 at 9:53pm |
Will the WC Starter and Distibutor Points work off 6 or 12 volts? I know the generator will be one or the other, but I was told the starter would run fine off either, is that correct?
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2696 |
Posted: 03 Oct 2010 at 10:02pm |
I have my Dad's WD45 that was converted to 12v without changing the starter over forty years ago. It has an alternator and a resistor mounted just before the coil. You don't want to keep grinding on the starter if it doesn't start right away.
Edited by JW in MO - 03 Oct 2010 at 10:07pm |
Sheridan-Utah
Joined: 16 Jan 2010 Location: Southern Utah Points: 107 |
Posted: 03 Oct 2010 at 10:04pm |
The starter dosent care if is 12 or 6 volts. I run 12 volts on all my tractors. I dont know about distriutor points,
HANSEN'S OLD ORANGE IRON
We show, pull, & go! |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 04 Oct 2010 at 8:16am |
Starter doesn't care on voltage nor on polarity. Points dont care , nor does the distributor. Coil does and needs to be 6V or 12V and polarity has to be right to tractor polarity. Using a 12V on ignition without a resistor either external or internal will shorten point life and cause failure of contact or point arm overheating and bending. |
