WC spark plugs
Mark.Kuehn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark.Kuehn Quote  Post ReplyReply Direct Link To This Post Topic: WC spark plugs
    Posted: 28 Oct 2024 at 5:16pm
I'm attempting to find modern replacements for AN7 or AC45 plugs.
I read that Champion J8C is possibly an equivalent and so is NGK CS3. Is this true, and what have others used successfully?
If the plug is a match for depth (length), diameter, and thread is there a risk of using an equivalent plug?
Edited by Mark.Kuehn - 28 Oct 2024 at 5:41pm
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 5:32pm
I run Autolite 295’s in my WC
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 6:12pm
The NGK equivalent for an AC45 is a B6S non resistor, if you want a resistor plug use a BR6S.
 Back in the 70s I quit using Champion plugs for anything. In a box of 10 you could be sure 2 were bad, it was up to you to find those 2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 6:47pm
Autolites or NGK's are usually the strong picks for AC Tractors. Autolite 295's are a warmer plug. The other Autolite choice that can be used is the 303. These are a little colder plug. Worn engines or engines that have some time on them where oil control may be a little bit of a problem, the 295's work great. The NGK B6S work great also. The choice is yours...
Steve@B&B
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 10:33am
Your WC should have a magneto unless it's been replaced with a distributor.  Magnetos don't like resistor plugs or carbon core wires!
