wc rims
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Topic: wc rims
    Posted: 25 Mar 2010 at 9:22pm
When did they switch from 6 bolt to 8 on the rear rims, and how hard is it to find one piece steel rims that fit the 6 bolts. would like to run around a 16.9 tire, but am having trouble finding a rim i like
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 9:29pm
Someone will correct me if wrong but I didn't think they had 8 bolt on WC's and the one piece steel rims were 24" from 1938 and 1939.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 10:51pm
That's correct the pressed steel WC rims were 24" & only 8" wide & would not work well with 16.9 tires. WC changed from 6 bolt to 8 bolt at the same time that they changed from hand brakes to foot brakes. That was when the WC became the WD in 1948!!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 5:58am
The original tire size for the WC was 11.25x24. That's the real old numbering system later called 13x24. The same size tire today would be 14.9x24. That's mounted on an 8" rim and the tires would stand taller because of the narrow rim but 16.9 would be a stretch on 8" rims I would think.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 7:21am
So can a wc be modified with wd hubs to allow installing 8 bolt rims?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 11:28am
The hubs do not interchange, but there are both 6 bolt to 8 bolt and 6 bolt to 9 bolt wheel adaptors available. If no one responds on this site, post a request on the Tractor Puller section of the YT Mag site. Kip
bucksnortAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bucksnortAC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 11:33am
i have a set of original stamped wc 24" rims for sale and i also have a very wide pair of 24" rims that have six loops in them.  centers could be made for these that would fit your wc with no problem.  email me if you are interested.  buckagg@yahoo.com
keith
