WC rear wheel center
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Topic: WC rear wheel center
    Posted: 15 Aug 2013 at 12:41pm
Has anyone ever made or attempted to make centers to bolt onto the rear hubs of a WC? I have old duals I want to make centers for and weld to the outer rim, just wondering And if so how was it made?
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2013 at 12:51pm
 Sounds like your trying to re-invent the wheel ..... its called re-rimming......
    I used existing centers F&H 28"  off an F-20 Farmall ,  old F&H flatspokes would work too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2013 at 1:36pm
Yes there are stamped wheel centers out there that will bolt to the WC hub. I have seen them advertized before, can't remember where.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2013 at 6:09pm
See the problem is I want to run 16.9x34 tires which I already have and was thinking about making my own center to built to the hub and then use 2x3 square tubing to go from the center to the rim instead if cutting a good pair of wheels up to make mine work
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2013 at 6:43pm
Not much difference from 28" to 34", can you weld clips on the rim to bolt to the cast center like they do on high crops? Or don't you use cast centers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2013 at 6:52pm
MNLonnie, guess I never thought of doing that, sounds simple and easy!
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2013 at 8:51pm
Find wheels from a Farmall F30...the bolt on style bolts up.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2013 at 10:16pm
I've got a set of 38 inch wheels with c channel welded to the rims that bolt to the centers which are a flat 3/8 inch still I'm guessing homemade centers
This page was generated in 0.266 seconds.
