WC rear RC gear swap. |
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Topic: WC rear RC gear swap.Posted: 15 Apr 2013 at 8:15am |
I have a question .. My WC has the rear end cut out lever, so you could lift the cultivator with the tractor stoped. The RC doesn't have this option. So if I have the the missing rear pinion bearing instaled in the RC third member will it be strong enough to handle the power or do I need to find a wc rear member to put the RC gears into.
Thanks for the Info and response.
mattb
Posted: 15 Apr 2013 at 9:45am |
use wc carrier rc only has two spider gears and will break seen it happen with a stock 226
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11847 |
Posted: 16 Apr 2013 at 1:24am |
The WC also has a 'straddle mounted' pinion, which the RC does not have. That means it has bearings on both sides of the gear.Some WC's (high clearance models) had the same ratio gears as the RC...
