WC rear RC gear swap.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Topic: WC rear RC gear swap.
    Posted: 17 Mar 2013 at 5:57pm
 Can anyone tell or show the details of this swap. Thank You.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2013 at 7:10pm
i am in the process of swapping the whole rear-end,itsonly 4 large bolts-then push it back,it slides right out.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2013 at 7:32pm
Does anyone make a ring and pinion conversion for WC rears? Or is the RC rear swap the only way to go?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2013 at 8:03pm
the rc or the high crop is the only way to go
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2013 at 8:28pm
We just swapped the entire rear end. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 6:16am
More engine HP is the way to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 2:52pm
I won't argue that but it can be tough to run 3.5mph class especially if I go to taller tires....all I've ever heard was high crop or RC rears. ..just didn't know if there was an aftermarket or something else that can be made fit relatively easily like 8 3/4 mopar rears in cub cadets.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2013 at 5:39am
Benny, if you find out something like that, please post it.  I put a speed patrol rear end in mine which is real slow, makes a huge difference with little engines (like mine)  Stock is around 4.4, picker/RC is around 6.6 and this one is about 7.2.  I have loaded mine to 6500 and run low gear with 38's and done pretty well at the local track.  Don't go much more than 4500 national and thats really no place for mine...just having fun
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2013 at 9:58am
I'd love to find a rear for mine.....
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2013 at 10:25am
There are a lot of advantages to using the lower ratio gears, if you go to a big motor, in non-speed limit classes, you can pull road gear which puts more power to the rear wheels by eliminating the gear train in the transmission, with a smaller engine it gives you more choices by making all three lower gears useful. Swapping the whole rear end housing is the easiest way to do it, but be advised that the RC rear end is made with smaller bull gears and axles, and the differential is a much lighter 2 pinion design, where the WC uses four pinions and the bull gears are 50% wider and the half shafts are heavier. I prefer the early (pre-39) differentials because the pinions seem hold up better even though they have fewer teeth, but you really need to watch the condition of the pinion cross in the older tractors, they are notorious for being severely worn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2013 at 11:05am
Thanks for that info Ken.  I swapped the whole thing out, both mine and donor rear are 1940.  I was also told that too about running road gear.....now just need some cubes to use road gear someplace other than the barn yard going to the trailer :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2013 at 7:27pm
So If I just use the ring and pinion have the end of the pinion milled to accept a bearing and use the wc carrier . The Rc has no cultivater kick out. Love that little lever to wait in line with. I have ti put the rc rear back together with wc ring and pinion to be a restoration project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 10:18am
Yes, in order to use the RC gear set in the WC housing, the end of the pinion shaft needs to be ground between centers to accept the tail bearing. It's a simple job for any competent machine shop, probably cost you $30 or $40.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 7:54pm
the sherman step-down would be an idea,im not sure how much slower it would make it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 8:13pm
The Sherman step-down is a great idea, just very hard to find and very pricey.
Davewestnewyork View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Davewestnewyork Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 8:08am
I have got a RC rearend if you are looking for one
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 10:34am
How much Dave? PM me a price.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
