Wc rear axle shaft seals
MaddMatt1969 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMatt1969 Quote  Post ReplyReply Direct Link To This Post Topic: Wc rear axle shaft seals
    Posted: 15 Feb 2023 at 6:09pm
Anyone know where I can get them ? The original is the the 2 pc seal that goes in a 1940 WC
T Hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 6:57pm
I believe the national seal number is 6150. I do not know if its avaliable. But.... I take the seal out of the intermediate housing. Be carefull not to distort it and use a Napa Chicago Rawhide cr19229. Then reinstall the assembly back into the axle housing. I've doe a dozen tractors this way with no fails.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 7:12pm
I have some NOS ones that are for the WC/WF tractors. These are the ones that go just outside if the differential. Some have a very large OD and others look more like a normal seal. What id the number on the ones you want to match? Or tell me the OD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMatt1969 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 7:16pm
Yes it is a 6150 I just ordered 2 new ones thank you for the info .
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMatt1969 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 7:20pm
Well if the ones that T Hunter told me about don’t work I will get back with you the outer of the whole assembly is 4.257”od 1.937”id
