Wc rear axle shaft seals |
MaddMatt1969
Topic: Wc rear axle shaft sealsPosted: 15 Feb 2023 at 6:09pm |
Anyone know where I can get them ? The original is the the 2 pc seal that goes in a 1940 WC
T Hunter
Posted: 15 Feb 2023 at 6:57pm |
I believe the national seal number is 6150. I do not know if its avaliable. But.... I take the seal out of the intermediate housing. Be carefull not to distort it and use a Napa Chicago Rawhide cr19229. Then reinstall the assembly back into the axle housing. I've doe a dozen tractors this way with no fails.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 15 Feb 2023 at 7:12pm |
I have some NOS ones that are for the WC/WF tractors. These are the ones that go just outside if the differential. Some have a very large OD and others look more like a normal seal. What id the number on the ones you want to match? Or tell me the OD.
MaddMatt1969
Posted: 15 Feb 2023 at 7:16pm |
Yes it is a 6150 I just ordered 2 new ones thank you for the info .
MaddMatt1969
Posted: 15 Feb 2023 at 7:20pm |
Well if the ones that T Hunter told me about don’t work I will get back with you the outer of the whole assembly is 4.257”od 1.937”id
