wc rear axle seals |
mike a
Topic: wc rear axle sealsPosted: 01 Jun 2019 at 10:49pm |
has anybody had the job of replacing the wheel seals in a wc? any good way?thanx
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Posted: 01 Jun 2019 at 11:09pm |
Front wheels or rear? I have a PDF of the WC service manual you're welcome to, shoot me your email if wanted. If you're doing the rear, be sure to replace the large cork gasket with the replacement rubber one, not cheap, bit over $50 these days, you'll need some large gasket paper to make the gaskets, I don't believe anyone is making them any more Edited by JoeM(GA) - 01 Jun 2019 at 11:10pm |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Posted: 02 Jun 2019 at 6:06am |
I did two. Messy job.
Gerald J.
Posted: 02 Jun 2019 at 9:44am |
I have the WC shop manual on line in 9 pieces in my Trees directory:
http://geraldj.networkiowa.com/Trees Total size about 80 Mb. Gerald J. |
oldways
Posted: 02 Jun 2019 at 10:44pm |
I just did mine a few months ago. The seals from agco didn't fit so well. After some searching I found out that they are the same seals as on a Dodge truck. I'll get the numbers tomorrow and post em on here and you can get em at any auto parts store. The big rubber outer seals you can get from guys on here or Agco. Like JoeM said you'll have to make the big gasket. Invest in a set of hole punches. Makes it go pretty quick. It takes a real heavy weight oil in those final drives Amsoil is the only manufacturer I found for that. I'll post it as well
Edited by oldways - 02 Jun 2019 at 10:50pm |
Pfouts Family Farm
Joined: 05 Dec 2018 Location: Hiram, Ohio Points: 177 |
Posted: 02 Jun 2019 at 11:24pm |
Mike, we have the original type cork seals. No squeak or squeal like the rubber ones. They sell for $65 per seal. If you interested, send me a pm or contact us with the info on our ad on this site. Thanks
oldways
Posted: 03 Jun 2019 at 4:52pm |
National oil seal part# 450094 or Napa # 19407 oil was Amsoil , sever gear synthetic SAE 250
oldways
Posted: 03 Jun 2019 at 4:55pm |
If you happen to take both hubs off at the same time make sure you put them back on the correct side they have a twist groove in them that keeps the oil in. Aslo I think some years had 2 different size oil seals in them. Not a bad job bud it's a messy job.
