wc rear axle seals
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Topic: wc rear axle seals
    Posted: 01 Jun 2019 at 10:49pm
has anybody had the job of replacing the wheel seals in a wc? any good way?thanx
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 11:09pm
Front wheels or rear? I have a PDF of the WC service manual you're welcome to, shoot me your email if wanted. If you're doing the rear, be sure to replace the large cork gasket with the replacement rubber one, not cheap, bit over $50 these days, you'll need some large gasket paper to make the gaskets, I don't believe anyone is making them any more
Edited by JoeM(GA) - 01 Jun 2019 at 11:10pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 6:06am
I did two. Messy job.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 9:44am
I have the WC shop manual on line in 9 pieces in my Trees directory:
http://geraldj.networkiowa.com/Trees
Total size about 80 Mb.
Gerald J.
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 10:44pm
I just did mine a few months ago. The seals from agco didn't fit so well. After some searching I found out that they are the same seals as on a Dodge truck. I'll get the numbers tomorrow and post em on here and you can get em at any auto parts store. The big rubber outer seals you can get from guys on here or Agco. Like JoeM said you'll have to make the big gasket. Invest in a set of hole punches. Makes it go pretty quick. It takes a real heavy weight oil in those final drives Amsoil is the only manufacturer I found for that. I'll post it as well
Edited by oldways - 02 Jun 2019 at 10:50pm
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 11:24pm
Mike, we have the original type cork seals. No squeak or squeal like the rubber ones. They sell for $65 per seal. If you interested, send me a pm or contact us with the info on our ad on this site. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 4:52pm
National oil seal part# 450094 or Napa # 19407 oil was Amsoil , sever gear synthetic SAE 250
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 4:55pm
If you happen to take both hubs off at the same time make sure you put them back on the correct side they have a twist groove in them that keeps the oil in. Aslo I think some years had 2 different size oil seals in them. Not a bad job bud it's a messy job.
This page was generated in 0.406 seconds.
