WC Questions-Rim, Brackets and Overdrive?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: WC Questions-Rim, Brackets and Overdrive?
    Posted: 08 Oct 2011 at 5:08pm
Hi guys-Can you please help me on these topics ?
  • Is this what the aftermarket rims are suppose to be like (have clip instead of a lug stamped into the rim)?  If not, it sure appears this rim is more like what a Ford 8N has.
  • What brackets are on this WC?  Cornpicker?
  • What is this box for?  Is it some type of overdrive (I was 6 when this tractor was parked so I don't remember what it did)?  Tractor's engine is stuck right now so I can't check that way either.
Thanks
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 10:17pm
You are right, that rim is wrong, don't know about the bracket but the box is a rearend disconnect. If you move the lever it will disengage the tranny from the rearend, if you remove that you can bolt on a cultivator lift.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2011 at 10:31pm
Just the top plate, then in gear you can use the mechanical lift. But that looks like someone may have put a hydraulic pump in there, which would work the same way. Otherwise the tractor must be moving in gear to use it.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 7:29am
the correct term for the housing bolted to the rearend is --- "traction release coupling" it disengauges the drive shaft from trans to rear end, one of the big complaints was when cultivating and you got to the end of the field and misjudged raising the cultivator you could end up against the fence with it still in the ground.If that happened you could dissengauge drive to rear axle and raise cult. also works for rotobaler to rap bale.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 7:33am
Since you've got the v belt pulley, I'd guess those brackets are for a corn picker.
AaronSEIA
Bud(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bud(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 7:37am
Those are corn picker brackets & the v belt pulley for driving the blowers on the picker.
