WC Questions-Rim, Brackets and Overdrive? |
nowaktj
Joined: 13 Dec 2009 Location: Elk River, MN Points: 735 |
Topic: WC Questions-Rim, Brackets and Overdrive?Posted: 08 Oct 2011 at 5:08pm |
Hi guys-Can you please help me on these topics ?
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4812 |
Posted: 08 Oct 2011 at 10:17pm |
You are right, that rim is wrong, don't know about the bracket but the box is a rearend disconnect. If you move the lever it will disengage the tranny from the rearend, if you remove that you can bolt on a cultivator lift.
Dipstick In
Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Posted: 08 Oct 2011 at 10:31pm |
Just the top plate, then in gear you can use the mechanical lift. But that looks like someone may have put a hydraulic pump in there, which would work the same way. Otherwise the tractor must be moving in gear to use it.
B26240
Posted: 09 Oct 2011 at 7:29am |
the correct term for the housing bolted to the rearend is --- "traction release coupling" it disengauges the drive shaft from trans to rear end, one of the big complaints was when cultivating and you got to the end of the field and misjudged raising the cultivator you could end up against the fence with it still in the ground.If that happened you could dissengauge drive to rear axle and raise cult. also works for rotobaler to rap bale.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 09 Oct 2011 at 7:33am |
Since you've got the v belt pulley, I'd guess those brackets are for a corn picker.
AaronSEIA
Bud(WI)
Posted: 09 Oct 2011 at 7:37am |
Those are corn picker brackets & the v belt pulley for driving the blowers on the picker.
