WC Part number
Gened67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gened67 Quote  Post ReplyReply Direct Link To This Post Topic: WC Part number
    Posted: 30 Dec 2015 at 6:44am
Restoring a 39 WC, Removed the main drive shaft from the front of the transmission because of excess movement. Found the inside roller bearing is beat up so bad I cannot read a part number. The shop manual page 65 item #2 lists it as " Bevel Pinion Shaft pocket Bearing. Anyone have a clue on a part number or where I can get one?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 7:46am
if i understand correctly you are looking for the bearing that is inside the end of the input shaft that the main shaft rides on?
70211537 is agco #
or old number should be 211537
also, you can view WC/WF parts book on http://www.agcopartsbooks.com
Edited by CAL(KS) - 30 Dec 2015 at 8:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gened67 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 3:45pm
Thank you so much for your help. I will post pictures of the completed project. "Orange Power"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 3:50pm
Take any old bearing to Motion Industries or other bearing supply stores d they can fix you up with a replacement , most likely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 6:15pm
I might have a NOS bearing
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 6:58pm
I have SKF 94520 written in my parts book, might want to check measurements though-
Brand:SKF
Part Number(s):94520
ProductName:ROLLER BEARING
Inside Diameter:25.4 mm,1 in
Outside Diameter:38.1 mm,1.5 in
Width:30.56 mm,1.2031 in
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
