WC only runs right with choke partially on
eversr007 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eversr007 Quote  Post ReplyReply Direct Link To This Post Topic: WC only runs right with choke partially on
    Posted: 07 Mar 2017 at 8:56am
Hi wondering if any one could help us with a problem that has been going on for a year or so.  So here is the story.   Dad has a 36 WC that my grandpa had and the engine block had a crack in it and one day it finally quit.  We use it all the time.  So we got a different engine out of another tractor and put a total overhaul kit in it.  After doing so it ran great but had to always have choke on partially to get it to run good.  So I checked for any air leaks.  Then thought might be head.  So we had the head redone at a machine shop and everything pressure tested.   Still the same problem.  I got busy and dad took to another guy that is good with tractors.  He tried everything even put a different carb on it and still no change.  The only thing that would be different that wasn't on the old engine was the manifold.  We put a WD 45 Manifold on it.  So could the air flow on that manifold not be enough with the smaller engine.?  Or do you all have any thoughts.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 9:08am
Open up the main jet on carb one full turn or more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eversr007 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 9:19am
Ok I will try that, but we tried adjusting it and nothing seemed to help.  I've never had trouble adjusting usually but I'm no pro with carbs.  So when we got carb adjusted where it would run right without choke on, It would spit and cough when pulled hard or run wide open.
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 9:38am
Is gas going to carb? Maybe screen plugged.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 9:40am
sounds like the float is sticking or not getting enough fuel
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 9:44am
Intake manifold may have a leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 12:32pm
Sounds to me like a lean condition. Intake vacuum leak. Pinhole or crack somewhere possibly. Engine may need a fatter mix under load if idle and off-idle are good at the Carburetor and under load is a problem. Fuel delivery problem to Carb... HTH
Steve@B&B
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 12:43pm
Steve@B&B
Spot on!
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 12:47pm
dad's old jd 3020....you had to do the same thing! dealer couldn't figger it out! the dude is sold that POS to asked me about it too....guess he still has to have the choke part way out.
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 2:15pm
I'm currently having the same problem with a wd45.  Also had the head redone.  Have 2 situations...carb and lower manifold ice up, so I put a thermostat in, idle for about 5 minutes until manifold heats up and ice goes away --- but then will still only run with choke half closed.  I've gone thru the usual, including 3 different carbs and 2 different manifolds; drained tank, pulled bowl assembly, new fuel line....still stumped.  I've let it sit for about a month now, will have to get back into it soon.
If ignorance is bliss, than happy days are here again.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 3:24pm
I have posted 17 times in the past 7 years on this forum about tuning carburetors and making engines run. The vintage carburetors are not factory tuned, they were tuned for each engine. intake manifold leaks can make partial choking necessary as can poor fuel supply to the carburetor, low float bowl level from improper float setting or fuel flow restrictions.
One of my longer posts is in the thread at: http://www.allischalmers.com/forum/forum_posts.asp?TID=90078&KW=carburetor+tune&PID=713218&title=update-on-my-rough-running-wd-again#713218
For more search this forum for the keywords carburetor tune posted by me for the last year and before with the advanced search.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eversr007 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 12:05am
So dad was using the wc and it quit running one day.  So we  put a new coil, condenser, filed the points, new rotor , cap, plugs and  plug wires .   That got it running again but still had to have choke on a little but maybe a little better.  tried to adjust carb and no adjustment did anything to how it ran other than when main jet was screwed all the way into seat.  Took carb apart and cleaned every jet with wire and blew everything out.  Put it back together and ran almost perfect without the choke on.  But when you put it under a load it starts to stall a little.  But no matter what you do with the top adjustment for the air mixture it doesn't do anything.  You can take it all the way out and doesn't do anything.  Bottom screw only changes engine when it is screwed all the way into the seat.  But no matter how far you screw it out it never runs rich.  Also put new needle valve and seat in.  Plus new float.  Any ideas???  One place told me to toss the carb and put one off a wd on it.  I think the one on it now is a Zenith 7078.  Also sprayed starting fluid on intake and carb and it had no change in sound.  Has me stumped.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 3:11pm
may haft to take the bowl mount out of the tank' an take it apart an clean it out' may have some crap down in there. blow it out with some air;;
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 6:13pm
Do you happen to have a filter between the tank and carb.?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2017 at 8:08pm
To adjust the carburetor jets for fastest running, you have to defeat the governor. Hold the throttle closed against the idle speed adjust screw and adjust the idle mixture for fastest running. Hold the throttle in a fixed position with the engine running 1600 to 2000 RPM and adjust the high speed jet for maximum speed.Might require unhooking the governor linkage. Otherwise the governor will hide any effects of the jet settings. The two adjustments interact so the sequence needs to be repeated several times.
Another thing to check is the centrifugal advance mechanism in the distributor. If its not working right due to rust or broken springs the engine won't run well at all speeds. it takes advance as the engine runs faster to allow for the finite time for combustion to take place.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 10:16am
If your not getting any change with adjusting the enrichment jet, there's a blockage or a problem (crack) somewhere deep in that Carburetor. The upper air/fuel mix screw is basically just for idle. The lower adjusting jet is for enrichment under load. (working)  If you crank that enrichment screw out at full throttle you should start to see a tinge of black smoke from the stack. After reinstalling your Carburetor and seeing how the engine ran much better with almost no choke, showed your cleaning method helped. These Carburetors can really get some dirt and debris jammed in their enrichment and idle circuits. Being I rebuild a lot of these Carburetors, I can't stress enough about making sure the fuel tanks are spotless, along with the fuel delivery systems. It doesn't take much for these Carbs to get messed up. The 7078 especially, being it was a dual fuel Carburetor to start off with. Distillate fuel wasn't the cleanest....
Steve@B&B
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 11:14am
A long shot, but check that you don't have diesel mixed with your gas.
