WC Governor Pin
Sheridan-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheridan-Utah Quote  Post ReplyReply Direct Link To This Post Topic: WC Governor Pin
    Posted: 02 Aug 2014 at 5:39pm
Does anyone know where you can get the long pin which holds the weights to the governor shaft?  Is there something you can use to replace it to attach them?
HANSEN'S OLD ORANGE IRON
We show, pull, & go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2014 at 7:23pm
Try an AGCO dealer.
28 702031931PIN, pivot, weight (Used Prior ENG. NO. W-135699)
Add to Pick List
702113682PIN (Used ENG. NO. W-135699 & UP)
Add to Pick List29702096551WEIGHT ASY. (Used Prior ENG. NO. W-135699) (Incl. Items 2, 3, 4, 27 & 28)
Edited by CTuckerNWIL - 02 Aug 2014 at 7:24pm
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2014 at 8:02pm
Interestingly, A-C continued to use pin #70211368 in the WD, WD-45 and D-17.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2014 at 5:24pm
Got new pins from Sandy Lake, think they were about $12 each with c-clips
This page was generated in 1.107 seconds.
