WC gearshift pin ?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: WC gearshift pin ?
    Posted: 02 Apr 2012 at 7:27pm
I need to replace the gearshift pin on my unstyled WC. I welded the groove shut and cut a new groove but the pin is a little sloppy in the shift tower so I want an over sized pin. Are they the same as wd b and c? Also sometime back I saw an aftermarket fix for the wc shifters. does anyone know where to get one? one last thing I need the long skinny rod that goes from the lockout lever by the shift knob down to the pivot point on the lower side of the shifter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 8:09pm
I bent up my own "new" rod for the reverse lock out release. I think I need a new OS pin for my shifter in the 35 also.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 8:55pm
   WE STOCK THE OVERSIZE PINS   1-574-342-4545
