WC gear shift fix?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: WC gear shift fix?
    Posted: 06 Jan 2011 at 4:30am
Does anyone have a good fix for the unstyled wc gearshift slop? I pulled the shifter and the pin doesn't look bad but the groove on the pivot ball is way wore.
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 7:04am
Most of the time the required fix consists of three things, repairing the hole in the shift tower, usually by reaming it oversize if you can obtain an oversize pin or opening up the hole and inserting a bushing to bring it back to  the original size, welding and re-machining the slot in the lever, and obtaining a new pin.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 7:26am
I have fixed about 3 of these-- build up grove and re machine I also made grove on the other side of ball and drilled 5/16 hol in tower then installed seconed pivot pit. HTH Mark
This page was generated in 0.103 seconds.
