WC fender repair
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: WC fender repair
    Posted: 16 Jul 2011 at 6:34pm
When I bought my wc at auction I also bought a nice set of fenders. The set on the tractor were shot. The other set were real nice all but one spot on the outside that had laid in the dirt for years. I cut the outer section 37 inches long and 1 3/4" wide out and cut the same from the original fenders. It took several clamps and a lot of time tack welding to keep the shape but it looks good. The outer lip on the replacment was between 1/8 and 3/16 wider so after I got it all welded up I had to grind down the lip and weld the fold back shut a little at a time. I'm now thinking of grinding out the rivits that hold the angle iron frame to the fenders so I can blast everything good. Where can I find replacment rivits and would they look original?
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 8:22am
Fastenall?
CarlMurphy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CarlMurphy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2024 at 5:47am
Opravdu potřebujete pomoc. Omylem rozbili záchodovou nádrž. Myslím, že by se ojetá nádrž mohla koupit samostatně podle reklam, nebo je lepší koupit novou sestavu toalety? V každém případě potřebujete pomoc řemeslníků, aby správně a spolehlivě vyměnili toaletu. Jsou v Praze dobří řemeslníci, kteří opravují vodovodní potrubí?
Darina View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darina Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 2:51am
Samozřejmě, že v každém městě najdete specializované služby pro jakoukoli opravu. Když jsem potřeboval oprava wc v Praze, obrátil jsem se na společnost MistrHouse. Tito specialisté si poradí i s náročným úkolem jakéhokoli rozsahu. Velmi dobře se orientují ve vodovodních a kanalizačních systémech všech typů, ať už se jedná o rodinný dům, chatu, kancelář nebo byt.
Edited by Darina - 01 Jul 2024 at 2:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 8:12am
well. Carl and Dar are a lot of help !!! ... translation...
You really need help. They accidentally broke the toilet tank. I think the used tank could be bought separately according to the ads, or is it better to buy a new toilet assembly? In any case, you need the help of craftsmen to correctly and reliably replace the toilet. Are there good craftsmen in Prague who repair water pipes?
Edited by steve(ill) - 01 Jul 2024 at 8:12am
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 8:29am
Where's Pat the Plumber when some one needs help!!! LOL
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 11:59am
WinkHave the terrorists taken to sending coded messages on this forum now?  How much more pure American goodness is there than honoring a long-lost American giant like Allis Chalmers was.
One load of BS is kind of normal anymore but the second one ConfusedConfused. I hope the interpolation  is close.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 12:56am
'AI' bots.
This page was generated in 1.797 seconds.
