WC Dilema |
Page <12 |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3133 |
Posted: 02 May 2023 at 9:33am |
Check the mains with a plastigauge and if they are in spec go wiht it. Also make sure it turns freely after torquing down the main caps.
Posted: 02 May 2023 at 12:26pm |
The odds of someone align-boring it to eliminate the shims would be VERY SLIM. Only tractor pullers do things like that. The set-up time and labor to do this exceeds the cost of the shims, so why would any farmer or implement dealer do such a thing ???
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 02 May 2023 at 8:33pm |
line boring my 45 was expensive 10 years ago
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 03 May 2023 at 6:17am |
Some people say line boring should always be done when rebuilding an engine. My argument (to that) is these engines easily went 60+ years with shims. The hardest work they will ever do, is mostly long behind them. Unless you are building an engine with extensive modifications, a shimmed crankshaft engine will probably easily outlive most of us.
SEIA Farmer
Posted: 03 May 2023 at 8:09am |
Like I said earlier in this thread, this is a family tractor. I purchased it from the original owner in 1977, and as far back as I can remember, 10-12 years before that, as I was 17 in '77, it sat outside his corncrib to run his elevator to put earcorn in the crib. It was his first tractor, then got relegated to "elevator tractor" after he upgraded to a WD, then later a D17. He retired from farming in the late 60s, and I faintly remember him using the WC before then. It was used to fill the crib in the fall, then he'd put a can on the exhaust and let it set, outside by the elevator, until the crib needed filled again. It had sat for so long, the tires were rotted off of it when I bought it. I would drive by on my way to town, and see it setting there, almost feeling sorry for the ole thing. The horseweeds would grow up around it in the summer, and you couldn't even tell there was a tractor setting there. After several attempts to buy it from him, he finally decided he wasn't going to use it anymore, and sold it to me for $25! I was a junior in high school at the time, and this was my first tractor! That's why I decided to restore a common ole WC, that'll never be worth what I've put into it!
As for the condition of the engine, it was loose when I got it, and after tinkering on it for a few days, I got it to run, but it started hard, so I just thought it needed overhauled. After using it for a water wagon tractor for a few years, it got replaced with a better tractor, and I sold it to my uncle, where it sat in his shed for 15-20 years until I bought it back from him. Dad said this old neighbor guy did most of his own mechanical work, but I have no idea what was done to the engine before I got it, except it'd been updated to the WD sleeves and pistons at some point. I have no idea what was ever done to the crank, if anything. Like I said, I don't have any evidence of it ever having shims on the mains when I took it apart. Here's where I'm leaning...I'm going to check the clearance on the mains again, and get some shims to add, if they're less than .005", to loosen things up a little. It had good oil pressure when I ran it, so if I use 30 wt oil in it, it should be OK. If I'm wrong, and it spins a main bearing, I've got a parts tractor that I can get a block from, and start over again! I know it sounds crazy to some of you, but I'm glad I don't need it to farm with, and I don't want to park it and forget about it again. I'm in too deep to stop now! Any suggestions are welcome.
Posted: 03 May 2023 at 8:22am |
You've ruined the front main bearing, which is undersized. I imagine you'll have to purchase another complete set of main bearing shells again. The machine shop can get the main cap shims in a "set". Get the new shims for the main caps and install them like any old AC mechanic would have done. It's the way it was designed to be. New bearings. New shims.
WF owner
Posted: 03 May 2023 at 9:36am |
If you aren't already using one, I suggest you get an Allis Chalmers Service Manual, not an IT manual. The AC manual is much more detailed and helpful.
SEIA Farmer
Posted: 03 May 2023 at 10:29am |
I have the AC Service Manual, IT service manual, parts book, and original owners manual (which has entertainment value only). The IT manual actually explains how to replace the crank bearings without removing the engine, so I'm going to get a new set of bearings and shims, and go that route. Wish me luck!
WF owner
Posted: 03 May 2023 at 10:33am |
You're a brave man! I would never tackle shimming a crankshaft with the engine in the tractor. I find it difficult enough with gravity on my side.
Edited by WF owner - 03 May 2023 at 10:34am |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 03 May 2023 at 1:38pm |
SEIA Farmer,
Well, I am running a WD45 engine with no shims on the crank bearings to block. The block was line honed by machine shop. Crank ground, new bearings installed throughout. Seems to run real good. Maybe it will lock up on the next event we enter, or during our plowing event next week? Not a high end expensive pulling engine. Just a good fresh engine build. I did scrape the seat areas on the sleeves until all the sleeves were approx .004-.005 proud, if I remember correctly.
Hope the engine rework in your WC works out for you, to be able to enjoy your Allis! Regards, Chris Edited by Sugarmaker - 03 May 2023 at 1:41pm |
Les Kerf
Posted: 03 May 2023 at 4:57pm |
It was not uncommon for farmers to file or grind bearing caps in order tighten things up a bit. These bearing bores need to carefully examined; a dial bore gauge and someone who knows how to properly use it would be in order.
SEIA Farmer
Posted: 08 May 2023 at 4:56pm |
Progress report: I got a new set of .020" under main bearings and shims, and started pulling things apart today to install them. Glad I decided to go with new bearing inserts because the top half of the front one that was siezed was in worse shape than the bottomhalf. The crank was acually not too bad to drop down to remove the bearing inserts. The IT manual tells how to do it, so that's why I got up the courage to go for it.
I did find something that I thought didn't look right though. When I pushed the inserts out, they were installed with both of the locating tabs on the same side of the bearing which also puts both of the oil holes in the inserts on the same side of the journal rather than opposite of each other. The service manual says to put the bearing caps on with the stamped number corresponding to the number on the block, which is on the gasket surface, towards the front left of the block. That is the way they were installed, which puts the tabs and oil holes on the same side of the bearing journal, which I thought looked odd. Shouldn't they be opposite of each other for maximum lubrication? Doc, please advise! I'm going to put it all back together with a new set of shims, then check the clearance with plastigauge to see if we're still within specs. Hopefully nothing was stretched too bad! If it's too far off, I should be able to file the bearing caps a little to snug things up?
Posted: 08 May 2023 at 5:10pm |
Some engine are tab to tab and other engines are opposite tabs. That's why I ALWAYS mark things. The book is correct in that the number aligns with the number stamped on the pan gasket surface. File on the main cap surface ?? You must be kidding...... Trying to plastigauge in-chassis with the weight of the crankshaft smashing the plastigauge doesn't really work either.
Edited by DrAllis - 08 May 2023 at 5:45pm |
SEIA Farmer
Posted: 08 May 2023 at 9:21pm |
This engine is tab to tab...the only main cap that could be changed is the middle one, but lining up the numbers is tab to tab, so be it. I put in the new inserts with 2 new .004" shims on each side of the bearing caps, and came up with .005" clearance after checking with plastigauge @ 85 ftlbs of torque. Should I remove some shims to get it closer to .002-.003"? What can I expect if I put it back together like that? Too much clearance, I know, but it had very good oil pressure before, so what will it hurt, with light use, to run it like that?
Like I said before, this is a family tractor. I'm not trying to patch it together just to pawn off onto someone to make a couple bucks. It's going to stay in the family, and I just want it to run well, so I can play with it with my kids and grand kids!
WF owner
Posted: 09 May 2023 at 5:09am |
First of all, I would use an AC service manual, not IT. The AC manual goes into a lot more detail.
I, personally, would go with the service manual specs, which IIRC is .002 - .003.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8989 |
Posted: 09 May 2023 at 8:33am |
No harder than it is to remove the engine to flip it and do crank work, I can't imagine why you insist on doing it the way you are. No time to do it right but time to do it over? Isn't plastigauge work to be done with dry brgs for true reading? Oily crank in frame with weight of crank hanging? Good luck.
SEIA Farmer
Posted: 09 May 2023 at 11:04am |
I have several reasons for doing it this way. 1) My shop time is extremely limited for "toy" projects this time of year, as my time is usually tied up with repairs on machinery I need to farm with, and field work. For me to "do it right", I'd need 2-3 weeks, which is only available in the winter. 2) I've got the head gasket issue sealed up and I don't want to remove it again. 3) The crank is hanging just fine with the connecting rods holding it in place. 4) I figured this old machinery was designed for shade tree mechanics to keep it running. The farmers that worked on these 80 years ago didn't go to the trouble to get the engine line bored, or checked over with a precision micro-bore gauge when it needed snugged up a little.5) Sometimes you have to go for it, and not get too uptight about things, to see what you can get by with. I'd rather be lucky than perfect any day!
I know I've got several of you guys shaking your heads and rolling your eyes at this project. I understand it wasn't done right the first time, I just want to correct it best I can with the limited timeline I'm up against. I want to thank everybody that's given advise and encouragement on it. That's what these forums should be for...to promote the antique tractor hobby, encourage the DIYers, and help us learn from our mistakes so others can avoid them. I've got the new bearing inserts ready to be torqued, and put back together. I've got a new set of shims, and it's come down to one question. Do I put two shims in (2x.004=.008" on each side) for a bearing clearance of .004-.005, or just go with one each side, and file the inserts for a .002-.003 final clearance? This is the point where I got at last time, and thought .002" of clearance was enough, without using any shims! This isn't going to be a pulling tractor, or do any plowing or heavy farm work. It probably won't get more than 10-20 hours of run time per year. What will it hurt to be a little loose? Like I said before...I just want it to start and run well, and not leave someone stranded in a parade!
Joined: 11 Sep 2009 Location: illinois Points: 90897 |
Posted: 09 May 2023 at 1:23pm |
.001 extra loose is a lot better than .001 too tight !
Les Kerf
Posted: 09 May 2023 at 4:12pm |
Your luck will be enhanced if you make certain that the crank is pushed up snug against the upper main bearing shell when you do the plastigage thing ![]() |
Sugarmaker
Posted: 11 May 2023 at 7:05am |
SEIA Farmer,
Your doing good! And your not getting feisty with suggestions about ways to do the work. You have a plan. And my guess is you will win. Might take a couple runs at it but we all do some of those things in life! The main thing is your "doing" not just talking about it! Good luck and I hope your family WC is running well for you soon! We need some pictures! Regards, Chris Edited by Sugarmaker - 11 May 2023 at 7:06am |
SEIA Farmer
Thanks(1)
Posted: 14 May 2023 at 5:14am |
Project Update: Engine is all back together and runs well. I went with a new set of .020 under inserts in all 3 mains, and put in the complete set of new shims. I can tell it's turning over and running much more freely than before. Yes, it can be done with the engine in the tractor, without removing the crankshaft. Nearest I can tell, is I've got .004-.005 bearing clearance using the plastigauge, which I know is probably not the most accurate way to measure things, but it's all I got, and better than nothing. The crank was sized, and the new bearing inserts should be uniform circumference, without being crushed from the shims removed, so I figured I've got a tighter engine than the majority of these old things that are still out there running with decades of wear on their bearings!
With the bottom issues taken care of, and the head gasket all sealed up, with all the fluids staying in their respective cavities, now I can concentrate on starting issues! I suspect that should be addressed in another new different thread, so we can put this one in the archives? Thanks again for all the comments and encourgement on this project, and I promise to get some pictures on here as soon as I can figure out how to do it! I think I'm going to have to have my IT guy (computer engineer son-in-law) help me out. He's much better with these "puter things" than I am! I know it'll be much faster, and less stressful for everybody!
Page <12 |
