wc clutch
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Topic: wc clutch
    Posted: 10 Jul 2010 at 3:52pm
putting my wc back together and having some issues....here's the first...i'm tired and cranky and must be missing something.  put the engine back in my wc.  before that i bolted the clutch assembly on the back of the engine and adjusted it according to the manual.  good news, engine started right up.  bad news, i have no clutch, and cannot put tractor in gear.  just grinds.  checked the adjustment.  manual calls for 1/4 inch between fingers and bearing.  i had about 1/2 inch.  adjusted it down to 1/4.  still no clutch.  readjusted down to an 1/8 of an inch, besides getting more of a pedal each time, no change.  still cannot put tractor in gear.  any ideas on what i'm missing here?  of course i'm in a hurry, trying to get ready for next week-ends show.....thanks  alan
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 4:03pm
do you have the disc in backwards
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 4:19pm
no, already checked that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 4:22pm
a few more bits of info....these are not the same components that i took out of the wc.  i switched the flywheel to one with a ring gear (i'm converting a 36 to electric), and used a different used clutch plate.  pressure plate is original.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 4:27pm
If you've adjusted the clutch that much and it didn't make a difference and still grinds bad,then it's either in backwards or it's badly bent. Since it won't work like that,you'll need to take the engine back out and unbolt the unit from the flywheel. Once you do that,lay the disc on the pressure plate and press around the outside edge of the disc with your thumb...if it jumps up at you,then it's bent and needs reflattened...if possible or a different one.  Rick
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 4:29pm
Both flywheels are the same depth...with the ring gear or without.   Rick
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 4:53pm
Broken finger bolt,maybe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 4:56pm
Is disc thicker than the one you took out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 8:37pm
rick--  you were right.  i pulled the engine out again.  not only was the clutch disk not flat, the metal portion was cracked and split.  i suspect i may have damaged it somehow when i was putting the engine in.....i didn't notice any major issues at the time, but i'm not sure what else could have happened.  i guess i should have had more than just the cat helping me guide it in.  anyhow, i put another disk in, put the engine back in the tractor, and now the clutch works.  thanks for the help.  now on to the next issues.  alan
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 11:58am
alan,
Glad you got it worked out. Sorry I wasn't any help. I wish the dr would clear me for lifting again, this detached retina thing is making me crazy. I have to come visit sometime soon.
Glenn
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 6:03pm
Rick knows all about clutches! That's is his living.
Now with that said, Rick don't get a big head on me! LOL
Don
