WC carburetor adjustment for starting
H_36754 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H_36754 Quote  Post ReplyReply Direct Link To This Post Topic: WC carburetor adjustment for starting
    Posted: 27 Aug 2023 at 7:42pm
I fixed the compression on my WC and now I'm trying to get it to actually start. I need to get the mixture adjusted to where it will run. Any suggestions?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 7:48pm
Will usually start with both adjustments 1 1/2 turn out.                 MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 8:34am
I'm wit' Mack on that. 1 1/2 turns out should get you a starting point and then dial it in as the engine gets up to normal operating range. If it still doesn't start, you have another problem somewhere. Timing, firing order, whatever.....
Steve@B&B
This page was generated in 0.158 seconds.
