WC brake stickin
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: WC brake stickin
    Posted: 21 Apr 2012 at 8:27pm
Noticed a small clickin noise, just as I let the clutch out in any gear on the LH final drive.
So I lifted that side up today with a floor jack, and found that the brake evidently is sticking a little on the LH side. When I rotate the tire, the hand brake lever just wiggles a little. Then settles down after I keep rotating the tire slowly.
I am guessing, that the inner seal is leaking oil onto the brake pad, causing it to stick slightly. Is this right?
Can I continue to use the LH brake, and maybe it will 'burn' off the oil? I really, really don't wanna tear into this one. Its been about 6 years since the restore, and just noticed this now. Had not done this in the past.
Galatians 5:22-24
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 10:00pm
If the inner seal were leaking iI would think it would be dripping out the hole in the bottom.  I'd have to take the top cover off and have a look, is it possible to have some rust on the drum?  Next guess would be something happened to the spring.  Just some thoughts.
This page was generated in 0.674 seconds.
