WC Brake bands
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Topic: WC Brake bands
    Posted: 04 Jul 2010 at 10:28am
I would like opinions on whether this brake band is worth salvaging and putting a new liner on it?  Was rusted pretty bad.  The other side is broke where the bolt goes thru the "eye", so I know I will have to replace it.  My question is whether most all brake bands I find in a boneyard will look like this or if this one is worse than average.  Was hoping I could find a couple decent ones in a boneyard to possibly put new liners on.
A new brake assembly with band and liner is $250 from Agco-so not looking that direction.
Thanks
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:14pm
Can't tell, but it doesn't look like it got into the metal band so I would put a new band on it.  I had to repair mine where the bolt goes through, put a new band on and is working fine.  just took some time with a welder, file and dremel.  Wouldn't want to do it every day.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 5:39pm
  I have  relined , rebuilt and  ready to go  $80  each with good core.  Tony
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 7:59pm
Get one from Tony and be don with it
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 7:13pm
If you have any oil leaks, you need to get the pads that don't care or fix your leaks
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
