WC block
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Topic: WC block
    Posted: 24 Jan 2025 at 12:49pm
Looking for a good wc block with a 12 bolt head. I’m in the process of overhauling the engine and had the head rebuilt but discovered the block is bad. Or if anyone has a good block for a 15 bolt head I would need the head also.
Grant Forsythe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 6:27pm
I might have some 12 stud motors coming in. What is the casting number on the side of it? Should be just below the magneto, U-3019-xx.
The Unstyled Collector
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 7:48pm
I’ll check tomorrow. 3019 sounds right. 48xxx serial number
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 9:17pm
call steve fischer @ 507-766-0551
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 11:50pm
I have a good no crack early 15 stud block. It is a U3019-5 casting number. $200 takes it. It’s located in Jordan,MN. Let me know if you would be interested in it. I might be baked to get some pictures of it this weekend if you want.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 8:12am
One of them is 45xxx serial. I’m located near Walcott Iowa. Should know in the next few weeks.
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 9:43pm
I found one. Thanks for all your help.
