WC belt pulley lubrication |
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Topic: WC belt pulley lubricationPosted: 12 Aug 2016 at 5:38pm |
Does the belt pulley on a WC run in oil, or is it just lubricated via the greases zerk? Says in the manual to take off the cover and add a little lubricant for extended pulley use? Thanks in advance.
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Posted: 12 Aug 2016 at 7:53pm |
The inner bearing runs in the transmission oil, the outer bearing is lubed with the grease fitting
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
