WC belt pulley lubrication
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: WC belt pulley lubrication
    Posted: 12 Aug 2016 at 5:38pm
Does the belt pulley on a WC run in oil, or is it just lubricated via the greases zerk? Says in the manual to take off the cover and add a little lubricant for extended pulley use? Thanks in advance.
The mechanic always wins.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 7:53pm
The inner bearing runs in the transmission oil, the outer bearing is lubed with the grease fitting
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
