WC air cleaner mesh replacement
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: WC air cleaner mesh replacement
    Posted: 29 Nov 2010 at 12:55pm
 I have the air cleaner all fixed up for my35 WC. I took the wire mess out and soaked it in solvent and it came out almost clean, My problem is if you jiggle any of the 5 sections of mesh, the wire breaks and crumbles. I'm afraid if a piece of this breaks loose while the engine is running, the quarter inch hardware cloth on top won't keep little pieces from being sucked into the carb.
 Does somebody make replacement wire for these or could a guy use a bunch of steel wool to replace it? Any ideas are appreciated.  Charlie
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 1:00pm
I don't think there is a replacement made.
Steel wool rusts and falls apart.
I'm sure someone on here has come up with something.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 1:04pm
TSC caries the replacement mesh. Seems likeit's around $17.00 a section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 1:20pm
Is the stuff TSC selling made for air cleaners or is it just a wire mesh for any purpose.
I never seen air cleaner wire mesh replacments at our store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 1:22pm
Thanks Bob, I will check that out.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 4:23pm
Some plastic or SS chor boys for scrubbing pots may work.  Friend used them for air cleaners on his bike, worked great in SS as he just coated them with light oil spray every so often
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 4:37pm
they told me to cut a bunch of disks from a fiberglass filter mat that they sell for furnaces.  I did it for mine.  went pretty quick...
Bruce(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 4:53pm
Stiener has it
Edited by Bruce(IA) - 29 Nov 2010 at 5:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 5:47pm
Thanks all, I ordered it from Stieners.
