water injection |
O.P.S. Heads
Topic: water injectionPosted: 08 Mar 2015 at 7:39pm |
If you are happy with its performance just spray a fine mist of water a foot or more ahead the turbo inlet. I would guess 15 ounces in 15 seconds to start with. Nothing fancy or expensive for a pump or nozzle. See what happens if it brings the temps down to 1700 then adjust to 20 ounces. Add water until you get to 1500 - 1600 degrees. That should be a safe number 1300 - 1400 even better. Anything over 20 ounces you may need to inject it after the turbo. Cheapest way to go to get things cooled off. Yes a looser turbine housing may help too, but I would use a little water first and see how it runs before changing any hard parts.
200 allis
Joined: 11 Mar 2014 Location: new jersey Points: 203 |
Posted: 07 Mar 2015 at 5:27am |
1800
200 allis
Posted: 07 Mar 2015 at 5:26am |
390 head on pump hx35 turbo with 12 cm exhaust housing timing at 33. Thought about trying 14 cm housing
O.P.S. Heads
Posted: 06 Mar 2015 at 10:50pm |
How high are they?
What is your turbo and pump combination? What is your injection pump timing set at? |
200 allis
Posted: 06 Mar 2015 at 10:24pm |
Could do both egts are high was looking to get under control
O.P.S. Heads
Posted: 06 Mar 2015 at 9:51pm |
For power, the intercooler. For lower exhaust temps, the water injection. Both will lower temps and give more power, but the intercooler will add a lot of power and lower EGT's a little where the water injection will lower temps a bunch (depending on how much water you use) and add a little power.
Has someone said "take your pick - one or the other"? If not I would use both. |
200 allis
Posted: 06 Mar 2015 at 9:44pm |
If u had to make choice on water injection or air to water intercooler which would be better choice
