Water injection help
ACman75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Topic: Water injection help
    Posted: 28 Feb 2017 at 9:33am
I'm looking for a good, simple way for water injection on 210 about 500 hp. Not wanting to spend a small fortune and wanting to use electric pump. Any tips or advice on setup would be appreciated. Thanks
Shawn PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 11:09am
Windshield washer fluid bottle. I got mine from like a mid 90's Grand Prix. It worked real well. And I could hide it easy too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 11:35am
What did you use for nozzle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 12:43pm
I drilled and threaded into the air tube before the turbo. And put a small ball valve in it and used that to regulate the washer fluid. Dr. Allis told me how to get the right flow. I think it was 12oz in 30 seconds maybe ?
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 6:10pm
Do you want to spray in water before or after the turbo or both? How many ounces in 15 seconds?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 6:43pm
I was thinking after turbo. Not sure about the amount?
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 8:32pm
Starter motor 12v hooked unto a high pressure washer pump include an inline filter ,buy an atomizer nozzle out of a sprayer book ,higher pressure with smaller nozzle will yield more power. I used to have a manual button on my throttle so if you were coming under just let go . 500-1000 psi range
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 9:15pm
That sounds pretty simple. Is most people spraying water with a little water soluble oil mixture?
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 9:25pm
These work well. Self contained tank, pump and 12VDC motor. I would use Simpson nozzles.
http://www.northerntool.com/shop/tools/product_200329758_200329758
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 9:06am
Okay thanks I'll check that out. I'm thinking an adjustable boost switch too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 11:19am
You could use a boost switch. I've always been a fan of a switch at the very end of the throttle stroke. It's simple and the driver has control that way. If the throttle is wide open the water is on - nothing to think about. An Allis push button switch like what's used to start the engine works well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 12:40pm
That's a good ideal! Just water?
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 1:55pm
Put a little water soluble oil in with the water - not mandatory, but probably better for the pump.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 11:25pm
any one remember the Harrison system? Used standby pressure from a hyd pump to pressurize a hydraulic cylinder filled with water on the base side ,  A solenoid turned the pressure on to the rod end this pushing out the water at what ever pressure the relief was set at on the hyd valve.  The water was fed to a 1/4 braid hose to six nozzles inserted into 6 drilled and threaded holes in the intercooler lining up with the intake ports.  Simple  .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACman75 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2017 at 1:55pm
Okay thanks for the help guys!
This page was generated in 0.131 seconds.
