WANTED !! |
Tony.Or
Topic: WANTED !!Posted: 05 Jul 2018 at 6:05pm |
Need HD5 B parts , out put Splined shaft with U-joint & end yoke .. Part number 065481 .
Also recoverd or excellent seat bottom seat back & sides for same .. Thanks Tony 877-602-3994
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35650 |
Posted: 05 Jul 2018 at 6:31pm |
Check with General Gear, in Idaho, may have some of it.
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 08 Jul 2018 at 7:37pm |
you will be lucky to find a good one as they all wear as they are not lubricated. on a fair one I have on mine I drilled and tapped for a grease fitting and lube it occasionally. it will prolong the life and take up a little of the space that is worn.
