WANTED: WD45 Spindle Supports/Spindles-wide front |
ssccrab
Topic: WANTED: WD45 Spindle Supports/Spindles-wide frontPosted: 06 May 2021 at 7:09am |
I'm in search of spindle supports and spindles for my a wide front WD45. The spindles on it currently are completely seized and seems like no amount of PB, heat, or beating on it will push them out. Any help is appreciated!
Edited by ssccrab - 06 May 2021 at 7:21am |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 07 May 2021 at 7:55am |
If I remember correctly there is a keyway in the Steering Arm.
You have to turn the Steering Assembly upside down and pound the Steering Arm off the Spindle. G |
Gary
Posted: 07 May 2021 at 12:27pm |
SS Did you understand my post about the keyway, and that is not the problem? Gary |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 07 May 2021 at 10:21pm |
Been a long time since I worked on mine but I believe the 2 tapered bolts hold the arms with no key. Should be able to remove taper bolts and then arms.
ac-mike
Posted: 10 May 2021 at 8:31am |
Bring them to me and I will disassemble them. Will not hurt them anymore than they already are.
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
d17brown
Joined: 11 Sep 2009 Location: farley iowa Points: 1737 |
Posted: 10 May 2021 at 3:31pm |
I have the wide front axle for sale. 300$. In iowa can ship
phil
