Wanted to buy:A.C. HD20 rear sprockets & rails
headwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote headwrench Quote  Post ReplyReply Direct Link To This Post Topic: Wanted to buy:A.C. HD20 rear sprockets & rails
    Posted: 30 Dec 2016 at 10:43am
I am looking for A.C. HD20 rear sprockets & rails, new or good used or for whole parts machine Thanks
Gordy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 4:05pm
This 21 is still for sale call 2698325994
“If you can't explain it simply, you don't understand it well enough”
Post Options Post Options   Thanks (0) Thanks(0)   Quote headwrench Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 4:23pm
Thank you
Brent.eggers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brent.eggers Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 11:54am
I no a fella with good sprockets. But don't have rails
Post Options Post Options   Thanks (0) Thanks(0)   Quote headwrench Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 8:11am
Thank you How would I contact him?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 5:41pm
look at the phone # above the picture?Wink
If you wanna contact brent, send him a PM, through the site.  Note this might not work, till you have the requisite # of posts, per site rules...Wink
Edited by DiyDave - 04 Jan 2017 at 5:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brent.eggers Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 8:12pm
This is Brent Bob Wetzel Is the mans name he is in the Nebraska his # is 4026762057 I just bought some HD 20 stuff from him the other day I have two HD 20s I have one that either I'm going to parts out or fix up myself so I might even have some parts   My number is 620778 2905 i'm in Kansas
Post Options Post Options   Thanks (0) Thanks(0)   Quote headwrench Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 9:38pm
Thank you Brent for the info I will do some calling
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 12:26am
Bob Witzel is his name
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brent.eggers Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 6:38am
Yes it is & I spelled it wrong   I thought I sent that in a pm. Too but yes he's a great fello
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 8:44pm
Early HD-21 rails should fit on an HD-20 ..  Try John Parks at General Gear.. Phone 208-342-8911..
Post Options Post Options   Thanks (0) Thanks(0)   Quote headwrench Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 9:53pm
I have tried General Gear They have nothing available Thank you for your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 12:53pm
Should be 9" pitch same as D8H or K, Komatsu D120/135 bushing diameter may be slightly different, would have to measure the inside/outside width of rails to see if will work on AC rollers. Could do a weld on Cat segment section from one of their sprockets to make it easier.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 4:45pm
This came up at Red Power
For the record go down to Rawleigh99 on page 12 and follow "Sprocket rim replacement D7 - D8 and posts following.  From Cat.
http://www.redpowermagazine.com/forums/topic/93000-td6-dozerloader/?page=12
Post Options Post Options   Thanks (0) Thanks(0)   Quote headwrench Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 10:01pm
This page was generated in 0.168 seconds.
