Wanted. The foam for a 200 cab
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: Wanted. The foam for a 200 cab
    Posted: 18 Jan 2021 at 4:46pm
Just the foam part that is in the lower front of the factory 200 cab, above the dash.   Mine is rotten. I cannot find a part # for it. Pm me with price if you have it. Thanks Guys.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2021 at 8:34pm
Check with Fehr.  They make kits for all manufacturers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 5:08pm
I will ckeck with them maybe it comes with a cab kit.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 7:44am
I used Fehr’s model search for 200 & this is what it showed. I have called Fehr & talked to owner for more details. Great company!
https://www.fehrcab.com/search.php?category=1942&search_query=%22200%22§ion=product
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 10:13pm
Thank you for the website. It does not show the foam part I need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2021 at 11:09pm
No worry. Just call Fehr during their office hours. Inform them of what you need with shape, measurements, & color choice and they’d probably fix you up with a specific precut piece or send you a bulk piece that you could trim to fit yourself. They’re good folks to work with at Fehr.
Here’s their contact info
https://www.fehrcab.com/contact-us/
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2021 at 2:08am
The 200 has a kind of odd piece right there. Thick, wide spongy rubber. If you find a source let us know. Maybe AGCO still has it........... probably be $300 if they did...... or more!
Wink
I am a Russian Bot
xbk9576 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote xbk9576 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2021 at 3:25pm
discontinued from Agco Hy-Capacity has them but hole kit
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 7:38am
Then I'd call Hy Capacity or a dealer that handles HP because it used to be you could order specific things from them when I worked parts at the CaseIH dealer. But that was 20 years ago.
Edited by Lonn - 23 Jan 2021 at 7:39am
Wink
I am a Russian Bot
