WANTED - Model #82 Sickle Bar Guards
D17IV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17IV Quote  Post ReplyReply Direct Link To This Post Topic: WANTED - Model #82 Sickle Bar Guards
    Posted: 03 Mar 2023 at 11:28am
I am looking for 15-original sickle bar mower guards (without replaceable ledger plates) for a model #82 mower.    Thank you in advance.  Brian from Ohio.
B110, 1937 WC, CA, 2-WD45 Diesels, D14, 2-D15 Series II and 2-D17IV
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 11:55am
Are you looking for NOS or used take offs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17IV Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 12:01pm
Good used would be fine.     Possibly NOS depending on the price.   Thanks.
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 1:44pm
I have an 82S  that is without mounting brackets & rear pulley, would part or sell as what's left.  Near Pandora OH  45877.  A.J.  419-230-3362
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2023 at 9:31pm
I am in the same position, are the wear plates available to replace? Ford G81-0807 guards are available locally. Just wanting to stay AC. I’m using Hershel serrated sections.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2023 at 9:40pm
The guards with rivet holding a ledger plate. Yes the ledger is replaceable. I can see if I have any left if you’d like
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2023 at 10:01pm
Thanks Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2023 at 10:10pm
I use the twin New Holland on mine with 1 AC guard. Works great, mowed a bazillion acres over the years. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2023 at 10:23pm
I will keep that in mind Tracy. Do you have the guard number in case I can’t get enough ledger plates?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2023 at 10:26pm
What sections are you using Tracy? I’m using Hershel A+
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2023 at 10:41pm
I don't remember on part numbers. The Herschels I use are the same hole spacing as AC are.Those ledger plates are tough to replace correctly. Need a good heavy setup for head side. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 12:03am
Part number should be stamped on it. I don’t think the guards on our NH 451 mower will fit but I should check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 12:14am
The A+ fits the same hole pattern as the AC sections. Just depends if your using the regular sections or the serrated? Better known as Tiger shark sections they really do a nice job of cutting as long as the ledger plate it good. Especially orchard grass and fine grass as I am used to cutting. I will admit replacing ledger plates is not something I am accustomed to so I am interested to find out how to properly replace them. Otherwise I will need to use replacement guards instead. Thank you Tracy for your wisdom
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 7:07pm
Easiest way is to drive them out from ledger plate side of guard. You can drill counter sink head off if you want to, but takes practice. Need to have the guard you are working on supported well. You can leave on mower, use an anvil or short piece of railroad rail. Needs to be cleared for ledger plate rivet removal. Use a heavy punch with short tip to start them moving. Finish driving it out with longer punch. Shortest length possible. And to replace remove guard, insert ledger plate, install rivet, use a heavy punch or hardy tool in anvil, make sure ledger plate is tight to guard with correct length rivet, pound rivet with hammer, making sure ledger plate is tight to guard during process. HTH Tracy
