wanted INj Pump
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: wanted INj Pump
    Posted: 13 Apr 2010 at 5:05pm
lookin for a  Injection Pump off a 220 for my D-21, mine took a crap! 320 226 1182. Brian lee
Cowboy UP
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 6:49pm
you'd be better off fixing your pump. What do you mean took a crap? seized up? hard starting? rarely is one not fixable. And a used pump off a running engine will likely need attention also. send me a pm, I can repair it for you. Ed.
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2010 at 9:29pm
Let me look I think I have a pump for you also.  If not I should have the parts to fix it for ya also.  Just let me know if I can help.
Andrew Gubbels
Andrew Gubbels
Gubbels Restoration
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:23pm
think it siezed up, probly plugged injector, little veiw window full of metal. Fixable???
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 9:11pm
I have enough parts around here to fix one up, just gets more costly. I can tell further once it is torn down. A plugged nozzle can seize the H&R for sure. Is this a stock farm tractor, or puller? let me know if I can help, Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 5:34pm
ED  tryin to get as much as pump will give me, yes i do alittle pullin , nothin wild, 7080 injectors, diff gov spring for more rpms, thats about it
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 5:35pm
when i get it off ill send it your way
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 9:12pm
you can pm me. or I can pm you my cell #. thanks, Ed.
This page was generated in 0.221 seconds.
