WANTED: Duetz Allis 5215 FWA part..
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Topic: WANTED: Duetz Allis 5215 FWA part..
    Posted: 04 Mar 2010 at 12:38pm
Anyone know of one being parted out anywhere? I'm looking for the tie rod that connects front wheels, and the mounting brackets to the bottom of the differentials....sorry, I don't have any part numbers. Thanks in advance for any help. Chad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 10:52am
Still looking for the above...thanks aggain for any help. Chad
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 4:31pm
Call 717-359-4848 ask for Danny or Phil ,I am sure I seen one that was burt .
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 4:53pm
Chad, did you get my last message on your post a  while back, saying that there is not a tie rod between the front wheels, but rather a rod running from operators on both sides of the tractor to each front wheel? Hope I'm of help.   Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 6:40am
Thanks Fred, I'll give 'em a call. Darrel,  I did read your post and it helped. I'm installing a power steering kit for a 5215 on my 5015. The instuctions clearly show a tierod running paralell with the front axle....that's where I'm confused. Maybe the later 5215's had a set up like that? For the most part, it bolted right on but right now the left and right wheels aren't on the same page. Thanks for the help. Chad
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 9:22pm
Chad, I called my neighbor that has my 5215 borrowed and had him check out the steering on it. It has a tie rod between the front wheels just as you are thinking. So I guess there is another difference between the 5015 and the 5215. So I guess it's like this: 5015 has no side to side tie rod, but a front to back rod on each side. 5215 has a front to back rod on right side and a tie rod between front wheels. Sorry I took so long to get that all straight for you.  Darrel
This page was generated in 0.069 seconds.
