wanted: d10/12 grill guard pics |
caRon
Topic: wanted: d10/12 grill guard picsPosted: 04 Jun 2010 at 4:12pm |
Gonna have a guard made up for the ca. Looks like there were 3 different types made for the d10 12/ca. Can I get some pics to see which will work best on a ca. Thanks
caRon
Posted: 05 Jun 2010 at 5:38am |
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 05 Jun 2010 at 7:02am |
I helped Tracey Martin so he could make some .Not sure if he is going to make any to sell .
Fred in Pa
Posted: 05 Jun 2010 at 7:06am |
Here is the one on my grandsons D-12
caRon
Posted: 05 Jun 2010 at 3:19pm |
thanks fred, nice pic. Does anyone have the guard that bolts to the front casting? Ron
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10876 |
Posted: 05 Jun 2010 at 8:18pm |
Fred, I plan on making some to sell. Almost finished with the D15-17 grill guards. Been real busy with paying work this year. Tracy Martin
DSpears N IL
Silver Level Access
Joined: 11 Sep 2009 Location: Rockford,Ill Points: 417 |
Posted: 06 Jun 2010 at 9:08pm |
Ca Ron & Tracey, It looks like that the steering arm on the CA may interfer with the grille guard that goes on the D-10 & D-12. How is that done differently?
DeWayne
Steve-KS
Joined: 14 Sep 2009 Location: Lawrence, KS Points: 5 |
Posted: 06 Jun 2010 at 10:02pm |
Here are a few from my d10. Hope it helps.
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 07 Jun 2010 at 11:52am |
Steve where did you get yours? I was at the Gray Tn. GOTO and there were several like that on several different make of tractors.
Dusty
caRon
Posted: 07 Jun 2010 at 9:21pm |
Dewayne, there should be enough clearance between the arm and the grille for a bracket. I have a model 8 loader on on this ca, so I think I will pattern the guard after the d10/12 guard that bolts onto the front casting. I can use the cultivator bosses on the ca casting, then run a bracket down to the side rails that mount the loader frames. Ron
caRon
Posted: 07 Jun 2010 at 9:25pm |
caRon
Posted: 07 Jun 2010 at 9:32pm |
steve, the guard on your tractor looks pretty darn good.
Tracy Martin TN
Posted: 07 Jun 2010 at 10:07pm |
CaRon, The diagram of the grill guard wouldn't work on a D10 or D12.The grill on a D10-12 is wider than the torque tube. The guard brackets have an offset in them.That way it can be fasten to tractor torque tube and front pivot bracket.That is the reason the guard is bolted together than welded. HTH Tracy Martin
Burgie
Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Posted: 08 Jun 2010 at 5:57am |
Tracy, Keep me in mind when you get the D15 series II done.
"Burgie"
caRon
Posted: 08 Jun 2010 at 9:46pm |
Tracy, I did notice that about the brackets. The #8 loader side bars fasten to the torque tube/front pivot bracket making it a little wider than the grill. I'm thinking the straight guard brackets like in the diagram will fasten to the side bars with the sub frames. What are the grille guard densions? What size material is used for the guard and the brackets, if you don't mind me aking? I know a guy who knows a guy type of deal, is going to try to make me one. Any advice? Thanks Ron
caRon
Posted: 08 Jun 2010 at 9:52pm |
I meant to write, What are the dimensions?
Steve-KS
Posted: 08 Jun 2010 at 10:20pm |
Its been on the tractor ever since i can remember. My granddad got the tractor back in 1966. My uncle says he put the guard on because grandpa kept beating up the front end. I'm assuming he got the guard from the same dealer he purchased the tractor from. Here's a picture of her back in '72 resting by the bunk house. I love this pic. ![]() |
Dusty MI
Posted: 09 Jun 2010 at 7:23am |
This is my new weight and grill guard that Snowman made.
Dusty
caRon
Posted: 09 Jun 2010 at 3:00pm |
Dusty, looks good. Snowman did a nice job. I didn't realize he also made the weight. Sharp!
