wanted 8010 steering tube
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: wanted 8010 steering tube
    Posted: 29 Mar 2010 at 9:38am
mine is FROZEN
before i hack mine apart to try to move setting- anybody have a new one?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 9:40am
Do you mean the drag link between the steering arms?  Try some (lots) heat at the clamp area and a means of applying tension to pull inner and outer apart.
The innovators offer what others will imitate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 9:41am
used the roasebu and got it HOT and it wouldnt budge
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 9:52am
Take the tube off of the tractor, get yourself some nylon straps and a chain ,hook one end to a tree or something that wont move hook the other end to a big tractor, we use a 210 start to put some pressure on the tie rod as you heat it with a rose bud and it will come out, but make sure you use nylon starps around the ball joint ends because using a chain will bend the ends. Or if you have a big enough torch and a 15 gallon drum or larger full of ice cold water heat the tube to a cherry red and throw it into the water totally submerged and a large enough quantity of water so the water doesnt just start to boil, let it cool and most times it will come out by hand. That process shocks the metal so bad that the rust and scale breaks its bond, just heating it eventually heats up the inner rod and it just expands together not freeing up.
