Voltage Regulators!
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2021 at 10:26am
1963D17
Welcome to the Forum, and thank-you for contributing your experience to help others
Generator Die Hards/Supporters
Regarding Mechanical Voltage Regulators, I would like to add a couple of key learnings I experienced recently when I performed a complete rebuild of a 1965 D17 Generator and installed new VR on the tractor.
Points
ensure the points inside the VR are clean and will conduct properly when closed, even a new unit
Grounding
clean metal (not thru paint) contact between the generator frame/tractor and VR frame/tractor to ensure good conductivity right back to the battery ground post
Polarizing
Remember to polarize EVERY time the Generator/VR/Battery circuit is disconnected
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
1963D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2021 at 12:34pm
Thanks. X100 on the grounds. Just had that on a guys 460. The regulator is under the fuel tank on those. A lot of dremeling with a wire brush and it was good to go.
Mike
